Hi Derek,
I don't know of anyone specifically who has made that conversion. Limit cycle hunting is always a problem with servos. It is actually a very complex nonlinear problem that depends on the mechanics of your system - stiction, friction, compliance, resonances, etc. The best defense is to have really high resolution encoders. I think we have some of the best tools for observing and minimizing the effect (Filters, deadband) but it can still be a problem.
Servo hunting and servo stability is most difficult where there are lots of components in the control loop such as with glass scale feedback. A second feedback device at the motor such as a tachometer or encoder can help a lot. You should be able to get your glass scale feedback working.
Yes you can have a 4th Step/Direction drive.
Message: 4309 |
Date: 3/25/2012 |
Subject: Re: Crusader 2 conversion |
Hello Troy,
I am having trouble remembering where your testing wound up on the HTML
controller. Does it work on your machine?
-Brad Murry
Message: 4310 |
Date: 3/25/2012 |
Message: 4315 |
Date: 3/25/2012 |
Thanks for the replies everyone.
I guess step one is to see if I can get motion with the existing system so I can see where I'm at. The Crusader system uses glass scales and tachometers so hopefully it should be a nice conversion. Fortunately this is a second machine so I don't have the pressure to get it going that I had on the first conversion.
Derek
